Jeep 84 CJ 7 Project Jeep
List the items you have for sale here!
Postby charlie crothers » Fri Sep 08, 2017 3:38 pm
Please email us for more pictures: EastCoastOffRoad@AOL.com.
Call us for more information: 717-429-4500, ask for Charlie.
This Jeep is in Delta, PA 17314.
84 CJ 7 6 cyl 5 speed $7,999.95 OBO
Motor: 6 Cyl --Motor re built (clean title)
We need to sell this Jeep!!! Contact us, we may even be able to assemble it for you at an additional cost. If you care to read the list is all the parts new never used that are included with the Jeep.
Weber carb assy
D.U.I (Davis unified Ignition & Distributor & coil T-5 Trans #1352066915-#1351097901
Live wire 7 mm shilded wires Dana 300 transfer case
New alt Painless kit wiring new 12 circuits
New starter Drive shafts all ok
New Motor mounts
Oil and filter
Headers
Belts-hoses
Power steering pump
Booster & master cyl
Frame: Reversed ft spring hangers kit & Shackles ft and rear
4" lift kit new with all new bushings New locking hubs 6 bolt
New caliper-pads-hoses
Re-located ft shock mounts New 6 bolt hubs & rotors
All s/s brake lines
Power steering box
Rock slide u bolts plates front and back
New u bolts
Energy suspension 1" body lift
P.O.R 15 coated frame
Pro comp MX6 Shocks
Model 20 rear/w 1 pc axle kit Yukon NEW 4:88 gears w/ master bearing kit
Custom model 44 kit ft rear cut down high pinion New 4:88 gears & MBK
Disc brakes
Body: NEW steel hub-fenders-grille-windshield frame w/ glass
Line a bed sprayed burgundy color-Out side
Line a bed black under body an inside body
4 factory flares
Tilt steering wheel
S/s cables for tailgate
Complete s/s bolt set from (Totally Stainless)
Dash- burgundy line a bed
Windshield burgundy line a bed also
New rubber windshield frame to body
All new heater-defrost cables- indicator light set
Plastic console locking w/ key
S/s mirrors
½ steel doors
Hard top
Tan bucket seats & rear seat
Spare tire carrier
(5) 37-12.50-15 super swamper tires mounted on 10 X15 chrome-black center wheels
Also all the headlights-tail lights all kinds of small items to many to mention
charlie crothers
Return to For Sale
Who is online
Users browsing this forum: No registered users and 0 guests
